TwinTurbo.NET: Nissan 300ZX forum - Re: Z won't start
Re: Z won't start
elcid
on February 04, 2013 at 5:01 PM
Z won't start
posted by edzy
on February 04, 2013 at 12:04 PM
I had the same issue. In my case the issue ended up being the after market alarm
Z won't start
edzy
12:04:38 02/04/13
It might be the blue starter relay which is located inside
Zvil (FL)
12:14:08 02/04/13
Once you find the starter relay you can jump it
white22sky
13:37:48 02/04/13
*I didn't mean once the wire is in place it will start up*
white22sky
14:17:44 02/04/13
check your clutch pedal to make sure the olive green grommet
Krazyd27(Houston)
14:04:37 02/04/13
Re: Z won't start
edzy
14:26:47 02/04/13
the starter relay is blue and it is just behind the
white22sky
15:16:41 02/04/13
Re: Re: Z won't start
edzy
09:12:16 02/05/13
No problem, please post up what you find. (n/m)
white22sky
17:32:27 02/05/13
Re: Z won't start -
elcid
17:01:19 02/04/13
Re: Z won't start
rudeboi805
02:14:52 02/07/13
This would not cause his condition.
white22sky
10:10:23 02/07/13
